concrete staining
Old 05-22-02, 09:02 AM
lholton2
concrete staining
I know nothing about this. I want to stain my patio. How do I do it easily and economically? Thanks, Lynn
Old 05-22-02, 07:20 PM
T
Received 2 Upvotes on 2 Posts
Old 12-10-07, 10:14 AM
C
Unhappy Fixing Stained Concrete?
I used a roller to apply a semi-transparent stain to my living room floor and now realized that this was a pretty bad idea. The finished color is full of lines and different levels of color. Is this fixable? I'm considering either a second layer of the same stain or a solid color stain. Not much of the floor is actually going to show as I plan to cover most in an area rug anyway, but I can't leave the bit that will be showing looking like this. I'm thinking the solid color is the best bet as i have a lot of repair holes from where the tack strip from the carpeting came up and it also stained a different color as well. Any help/suggestions?
Old 12-10-07, 02:49 PM
that's our work & we'd,,,
never apply acid-reactive OR conc dyes w/rollers,,, who ever suggest'd that has no earthly idea of what to do,,,
no, its not fixable but you may wish to try some sher-wms 877 (?) pigment dissolved in a conc sealer now,,, you could also try removing the stain (unlikely) w/a low-rpm buffer & black pad. didn't repair the tack divits 1st ? ? ?
conc dyes may be another solution but they're opaque, not translucent.
lynn, read 1st,,, there's a cure for ignorance but it ain't easy OR economical.
Old 12-10-07, 02:53 PM
here's some other,,,
sources,,, http://www.decorativeconcreteforums.com/forum.php
http://p196.ezboard.com/bconcretelocator
http://www.gayegoodman.com/dc_plus/d...pics&forum=136
then again, its difficult gaining experience from reading labels or forums but all the mistakes you'll make've already been made,,, or so it seems to me.
i make better ones :-)
