concrete in pipes
Old 05-30-02, 06:38 AM
shep011
concrete in pipes
while pouring a concrete floor i failed to cover drain pipes and it went in the pipes. how can i clean concrete out after it dried in the pipes. thank you
Old 05-30-02, 05:42 PM
Mike Swearingen's Avatar
Cool
You probably can't.
You're going to have to break up the concrete around those pipes, and replace the pipe with the concrete in it.
Good luck!
Mike
Old 05-31-02, 07:36 AM
pmg
If the pipes are plastic there is a slight chance you'd be able to snake it and knock some loose,then fllod the drain and see what comes out the other end if possible.Again,a longshot but worth a try
Old 06-28-02, 07:56 PM
MTgets
I know it is probably to late since this happened a month ago, but here is a little trick, if the pipes are plastic, dump 2- 2litres bottles of Coke a cola down the drain over a 8 hour period, then flush it out, it works most of the time when the amount is not to bad.
Mabye??
