basement window leaks
Old 06-09-02, 07:06 AM
W
Unhappy basement window leaks
My basement window leaks from a crack in the sill. The sill is at ground level. How should I repair this crack, and what should I use. I can see the crack on the outside and I can see where it comes in on the inside it seems to be a direct line.
Old 06-09-02, 11:20 AM
T
Cracks in basement walls
Large cracks can be filled with hydraulic cement or epoxy.
http://www.postconcrete.com/crackkit.html
http://www.concretenetwork.com/concr...ning_signs.htm
Correct defects: Soil should be lower than the sill and landscape sloped to carry water away from the foundation of the home. Make sure gutters and downspouts are clear and carrying water away from the foundation and are not missing or need repairs
Soil level should be at least 6 inches below the mudsill of your home. http://www.cornerhardware.com/html/articles/art44.htm
Perhaps a window dome would provide protection:
http://www.naturalspacesdomes.com/drdome/sec9.htm
If this is an egress window required by local building codes, there may be some important considerations:
http://www.hometime.com/Howto/projec...ent/base_1.htm
