Any opinions, experience buying classic VW Beetle
Old 10-18-22, 09:07 AM
G
I have available two 1974 VW Beetles for sale. Both in very good condition, excellent body and pans, heater channels replaced with verified low mies. One is the 4-speed manual trans and the other is the Autostick or Automatic Stick Shift transmission.
I see that many owners with the Autostick trans have converted their cars to Manual Trans. I am seeking opinions on which is the more desirable car.
Thanks for any input.
Old 10-18-22, 09:34 AM
Received 1,262 Upvotes on 1,203 Posts
I would not convert to sell them, only to drive if I wanted a manual and was buying the car for myself.
Old 10-18-22, 12:07 PM
P
Received 2,112 Upvotes on 1,891 Posts
Keep the car as original as possible. Most of their value is as a collectible so any modification has a good chance of decreasing it's value. If someone really wants that transmission, let them make the switch cause I doubt you'll get your money back from the conversion.
Old 10-18-22, 12:59 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
The auto stick was not a wildly popular option but as you noted it gets replaced often but that tends to be more due to part availability, when and/if repairs are needed rather than an all out performance issue.
I don't think I would use that as a deal breaker, the condition of the body/pan is primary.
Old 10-19-22, 06:58 AM
G
Thank you for the input. To me, all of the above is sound advice.
Old 10-19-22, 07:17 AM
Received 23 Upvotes on 21 Posts
If you are comfortable driving a stick shift that is likely the better choice. I know nothing about which has a better resale value. Those old VWs had small engines. I would not further burden it with an automatic. I suspect that is why many were converted from auto to stick shift.
