HD Antenna
Old 02-28-13, 05:21 PM
pgtek's Avatar
Received 1 Vote on 1 Post
Unhappy HD Antenna
Hi Folks
My rv is park on a campground that's pretty wooded.
My antenna is a windguard crank up type and has problem getting HD channel.
I have a hd converter in my rv but with so much trees around reception is so so
is there a better antenna out there for my rv
thanks
pg
Old 02-28-13, 05:25 PM
Received 1,505 Votes on 1,393 Posts
There is an attachment that you can put on that antenna to get better UHF (hi def) reception.
However..... HDTV is a very low power system. You will only be able to pick up stations for approximately 25 miles and then mostly line of site.
I left you a link for the part you can attach to your antenna. It does work. I have installed them and actually do notice the difference.
SENSAR RV VHF/UHF Television Antenna - #1 Antenna in the RV Industry!
Old 03-02-13, 07:06 AM
pgtek's Avatar
thank you
will give it a try and see if better
