Band saw set-up.
Old 03-09-03, 05:40 AM
GregH's Avatar
Super Moderator
Received 66 Upvotes on 61 Posts
Question Band saw set-up.
I'm setting up a 10" Delta bandsaw I got at an auction a while back and could use some advice.
I only have the saw portion with no stand or motor.
Making the base and mounting the motor is a piece of cake but I'm not sure how fast to have the drive wheel turn.
I have a 6-tooth, 3/8" .020" blade, and will use an adjustable pulley once I'm in the correct range.
I also know that bigger is better but will a 1/2 hp motor make this thing work?
Old 03-09-03, 07:48 AM
Herm's Avatar
A 1/2 hp motor would be sufficient to cut a lot of things, but may bog down the motor in heavier cutting. I would go with a 1 hp motor. Blade speed is different on different bandsaws, and can go anywhere from 1000fpm to 4000fpm. Somewhere around the midrange can be a good place to set it.
Old 03-09-03, 08:40 AM
GregH's Avatar
Super Moderator
Herm:
Thanks for the info.
I will get it set up with a half horse motor. I was looking through my motor collection and found a brand new 1/2hp Delta motor I bought at a lumberyard clearance.
I set-up all my motors to be quick change anyway.
BTW:
Do you know the math to convert 2000 fpm to the rpm of a 10" wheel?
Old 03-09-03, 08:54 AM
GregH's Avatar
Super Moderator
Hey!
I think I found the answer.
A really good conversion site:
http://www.simcotech.com/formulas/fpm.htm
Old 03-11-03, 04:37 AM
GregH's Avatar
Super Moderator
Update:
I've got my saw running with the drive running at 1035 rpm.
The calculator gives me 2710 fpm which will cut through a spruce 2x4 with no effort at all.
