Building a Wood Column or Round Structure
I am in the process of building a kitchen island that has a cast iron (4 in.) structural post on one end, running from the drop-down ceiling to the floor. Plumbing pipes were run parallel to the post. To enclose the post and the plumbing runs, I am going to build a square base, about 14 in. sq. (w) & 36 in. (h), attached to the side of the island. Then, build a column from the top of the base to the drop-down ceiling (about 6 ft. high).
Any ideas on how to build a wood column, or any round structure that I can cover with wood or steel paneling!
I called several lumber places and the column size I am looking for, which must be at least 11 in. in diameter on the inside to accommodate the post and plumbing runs, has to be special ordered. This takes 4-6 weeks and will be costly.
Thanks in advance.
Thanks in advance.
Received 0 Votes
One option that comes to mind is a Sonotube. This is used generically to describe the tubular forms used to pour concrete footings and pilings.
They come in 12 inch diameters, among others. I saw one 8 feet long listed, so the lengths must not be a problem.
They are durable, single use forms. I imagine that it would be the cheapest, quick way to get a column that you could cover with something decorative.
I would venture to say that you could find them at a building supply yard.
You can get plastic sewer pipe 12" in diameter, too.
Hope this helps.
Hope this helps.
