Straight Edge When Ripping Board
WHAT IS THE BEST WAY TO CUT A STRAIGHT EDGE WHEN RIPPING A BOARD THAT IS NOT STRAIGHT. I USED THE FENCE ON MY TABLE SAW AS A GUIDE CUTTING 1/2" OFF AT THE TIME TRYING TO GET THE STRAIGHT CUT BUT NEVER DID.I AM NOT EXPERIENCED WITH WOOD WORKING BUT TRY TO TAKE UP WOOD WORKING AS A HOBBY. I HAVE PURCHASED A NEW DELTA 10" TABLE SAW & YESTERDAY WAS THE FIRST TIME I HAD TRIED TO RIP A PC OF PLYWOOD OR ANY BOARDS.ANY ADVICE WOULD BE GREATLY APPRECIATED.THANKS IN ADVANCE FOR ANY ADVICE.
THANKS--MCCOY
THANKS--MCCOY
Received 0 Votes
If you don't have a straight edge on the board, the fence itself won't help much. Attach a straight board to the the target board and run it through the saw with the straight board against the fence, and make a straight cut edge. Dismount the accessory board and proceed. Some use double face tape to attach the accessory board.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
THANKS--MCCOY
If you do get serious with woodworking as a hobby, you will eventualy need a jointer. for now, pickup a sheet of plywood. rip a 12" wide and 8' long piece out of it. factory edge on a plywood is fairly straight. now you can clamp the board that you want to straighten on this piece of plywood so that it overhangs a bit on one side. keep one edge of plywood against fence & set your fence 12" away. rip the board & you will have straight edge. on one side.
--Rajiv
--Rajiv
--Rajiv
--Rajiv
THIS I WILL DO SOUNDS LIKE A GOOD WAY TO GET A STRAIGHT CUT. THANKS--MCCOY
Received 0 Votes
Try this, it has worked great for me. It is the same concept as what the others have talked about, but very simple to use.
Tru-Grip FT8TS 8' Tru-Grip Pro FTR Series
http://www.amazon.com/exec/obidos/tg...&s=hi&n=553160
