Uneven Floor - Threshold
Have hardwood floor installed in living room and adjoining kitchen that does not have a threshold/reducer piece installed. The floor in the kitchen is lower than the living room but the problem I see is that threshold transition is not level.
Left side of threshold/living room floor is about 1" higher than kitchen floor and the right side of the threshold/living room floor is only about 1/4 inch higher than kitchen floor.
Is there anything I can do? No idea how I would install a reducer on an uneven transition like this???
Received 0 Votes
Take a threshold/transition and plane to fit the difference. You can scribe the piece in place, then plane it to suit.
This explains scribing in general.
http://www.readersdigest.co.uk/diy/webpages/283_284.htm
Hope this helps.
Hope this helps.
