Cutting out the sink hole in post form countertop
Old 03-16-04, 02:36 PM
joeperi's Avatar
I have ordered a post form countertop with a backsplash attached. Because I don't yet know the size of the kitchen sink, I will cut the hole on site. So, what is the correct tool and procedure? Cut it from above or below? use a saber saw or router? Some other tool? Special blades/cutters? I know the idea is to avoid chipping the laminate. Someone told me to cut just shy of my outline and then sand. That's great until I get into the curved corners.
Any suggestions would be helpful.
Old 03-16-04, 05:33 PM
Furniture Bldr
Turn the top upside down, use an upcut blade. NO need to sand at all. Just make sure you cut the corners in a radius or you're going to be drinking heavily that night and be in one xxx off mood
Old 03-16-04, 09:13 PM
C
Many sinks come with a template for the sizing and shape of the opening.
Old 03-17-04, 02:57 PM
joeperi's Avatar
Dear FB, thanks. I assume you mean a saber saw/ jig saw with an upcut blade? How many teeth per inch do you recommend?
Thanks.
Old 03-17-04, 07:19 PM
Tom_J
joe,
I'm stealing from Bosch here, but their recommendation for laminated particle board is 16-20 tpi.
Tom
Old 03-24-04, 12:57 PM
Shadz
Be sure to apply 100% silicon sealer to the edge after cutting. This will help prevent water from getting underneath the laminate causing it to warp.
