Rabbit joint
Rabbit joint
I am not sure what a rabbit joint is or how to make one. I was told to use this technique to joint two pieces of wood together so they fit together at an angle without sticking out from the wall too much. How do I go about making this and what tools do I need to get the job done? Thanks!
Received 0 Votes
See figure 11 for an example of a rabbet joint.
http://www.dixieline.com/woodjoint/woodjoints.htm
Here is one technique for making a rabbet joint.
http://www.diynet.com/diy/hi_tools/a...056376,00.html
Hope this helps.
Hope this helps.
