Discoloration from wood putty
Old 09-08-04, 10:37 AM
Lightbulb Discoloration from wood putty
Hi,
I filled a couple of nail holes in a transition strip from tile to wood and then I polyurethaned the transition strip. Now 3 weeks later, the area around the nail holes seem to be discolored and a different color than the rest of the strip. What happened???
greenda4
Old 09-08-04, 10:42 AM
C
The liquid that softens and carries the putty has stained or contaminated the surrounding wood thereby interfering with the staining and finishing process.
Old 09-08-04, 11:09 AM
Lightbulb
Thanks for replying Chris! So is there anything I can do to rectify this problem??
greenda4
Old 09-08-04, 12:02 PM
C
Strip the finish and clean the wood. Wipe with mineral spirits before staining or finishing to see if any contaminants are present. They will look different from the rest of the wood when wiped with mineral spirits, lighter spots that show the mineral spirits did not penetrate evenly. That way you know what needs to be cleaned, removed, sanded, and so forth.
Hope this helps.
