Fold Down Wall Table
I am looking for a set of plans for a folding down wall table. Something about 3' x 5'. Folds down from the top hindge on the bottom and has legs to support it when folded down. Any ideas or plans?
rockinw,
Welcome to the forums.
The very first thread in this forum is a sticky thread entitled.
"Free Woodworking Plans & DIY Projects "
Please browse through that thread as there are links to many woodworking plans.
pg,
The link you mentioned in your last post does not appear. Can you post it again?
Thanks!
pg,
Thanks!
sorry forgot it
hi
here the link it only should vaque setup but i figure it out from the picture
http://www.cahe.nmsu.edu/pubs/_g/g-412.html
have fun
pg
have fun
pg
I saw an idea in a magazine that may work for you. It was four pieces of 1X6 quilted maple with a 4" edge of walnut, all tongue and groove. After the pieces were joined, a 1" hole was drilled in each corner, in about 6" from each side. When the piece wasn't in use, it was hung on the wall using hooks through the holes. When it needed to be used, it was set on top of two filing cabinets. I know this isn't exactly what you had in mind, but I thought it was a neat idea that accomplished the same result.
