Cabinet Door style
Old 02-17-05, 08:30 AM
howartp
Lightbulb Cabinet Door style
Hi,
I'm desigining a cabinet, which my grandfather is going to build for me, but I want a particular type of 'door' on it. However, I'm not sure what the door type is called, if it has a name, and my grandfather doesn't know where you would get one from.
THere's a picture here of the style I'm looking for - it's the up-and-over section on the right.
Any ideas what its called, and/or where I might find further information on it and/or where I might buy it (custom ordered or otherwise)
The cabinet is for an audio/visual Rack installation in a church.
Thanks in advance,
Peter Howarth
Old 02-17-05, 09:23 AM
Sawdustguy
It's called Tambor Door. You can make your own by using a heavy canvas and thin strips of wood. It's not really something you can just buy, that I know of.
Old 02-17-05, 09:49 AM
howartp
Thanks Mike.
I didn't think you'd be able to buy them, but at least I can look around for ideas now.
Thanks again,
Peter.
Old 02-17-05, 09:58 AM
D
Tambor door
You can get the kits for these. They are used on roll top desks and entertainment centers.
Old 02-17-05, 10:06 AM
howartp
Thanks.
I'll have a look around.
It's a pc workstation unit that I got the idea off (as you noticed if you looked at the picture), so I wondered if you might be able to.
Peter.
Old 02-17-05, 10:10 AM
D
Cabinet door
Anything is possible. Remember that the door rolls up and down the back side. If the depth is shorter than the hieght, it will have to roll down the back side of the cabinet to get it all the way open. Don't knock the cables off the back of the PC.
Old 02-17-05, 10:14 AM
howartp
It isn't going to be a pc workstation that I'm using it for - it's a Rack Cabinet as used in the a/v industry. Mixers/amps/cd players/effects units.... There'll be plenty of space behind the units for access to cables and switches, never mind the door chopping them off
Thanks for pointing out that it goes down the back - I knew about it, but I could just as easily not have done.
Peter.
Old 02-17-05, 10:55 AM
B
Originally Posted by howartp
Thanks Mike.
Thanks again,
Peter.
Check Rockler's, I think they used to sell tambor kits.
Old 02-17-05, 12:04 PM
Herm's Avatar
Peter,
Tambour kits are available from Rockler and other places. Do a Google Search for tambour door kits, and you'll come up with some ideas. Make sure you spell it right, otherwise you'll come up with some automotive stuff.
Old 02-18-05, 02:37 AM
howartp
Aha
That's why I couldn't find anything
Cheers
Peter.
