Wood glue solvent
Old 10-27-05, 05:22 PM
Wood glue solvent
Anybody know what I can use for an Elmer's wood glue solvent?
Old 10-28-05, 05:40 AM
Herm's Avatar
Elmer's glue is a water based glue, so cleaning it up with a damp rag is real easy unless the glue has set up already.
Are trying to detach two pieces that are glued together? Or did some get all over something that it shouldn't have?
Prying apart glue joined pieces can be done, but is tricky. A sharp chisel can be used to carefully clean excess glue off of some surfaces.
Hope this helps, but if not, please give more details on what you need to do.
Old 10-28-05, 08:38 AM
Working on a shadow box, and glued the 4 corners (I should know by now not to do that) with 2 framing clamps, and missed that one side was not completely squared. I fixed this project, but would like to know how to UNGLUE! for the future.
Thanks.
