angled holes for legs for stool
Old 12-02-05, 01:41 PM
map686
I am building a set of stools. they will have splayed legs and stringers. What is the best...(easiest and most accurate) way to get the angles all the same. I,ve been looking for drill press jig plans, but so far no luck. Any help would be great. Thanks, mp
Old 12-02-05, 02:48 PM
IBM5081's Avatar
Does your drill press adjust for compound angles?
If not, I would suggest getting a cheap stool, cut off the legs to about 6".
Put a drill bit in the press and drill straight down the center of the leg. Turn off the drill motor and leave the bit in the leg. Now build a wedge between the drill press table and the top of the stool (which is upside down at this point).
