Recycling Oak Flooring
Old 04-13-06, 09:47 PM
W
Hi everyone,
I have recently been given approx 250 sq.ft. of 3/4 oak flooring from my daughter. she had it removed from her house for some reason!!! , The wood has Many flooring nails in and I will be using it for a number of small projects..Not flooring. Just hate to waste good wood.
Q. Is there anyway I can removed these nails effectively, they dont have a head to grab and seems they are in there for eternity. Sure dont want to run them thru my saws -- chunk-clink .. as I will be removing the t/g.
Thanks.
Old 04-14-06, 05:41 AM
Received 293 Votes on 260 Posts
Can you drive the heads up enough to grab the nails with a pliers?
My work benches have yellow pine tops thanks to a house my brother in-law bought and remodeled but they did have a minimal amount of nails. I also picked and chose the best pieces and used the rest in the shop stove.
Old 04-14-06, 01:40 PM
K
grab a nailset and tap them through until you can pry them out
Old 04-14-06, 04:09 PM
chandler's Avatar
Received 5 Votes on 5 Posts
One thing else...buy a small metal detector to run up and down the boards. You can find them on the auction site or Rocklers, etc. A cheap investment versus 3 planer blades. You may miss a nail or one may have a broken head left in the wood.
Old 04-14-06, 09:05 PM
W
Thanks for the responses,, Will try all approaches, and get a nail / metal detector,, I do have a fairly strong magnet (cattle) , but maybe not strong enough to detect those buried under. I use it for finding nail / drywall screws, works decent. Nail sets too. WIll respond back when I do some if it,
Thanks, have a great easter.
Old 04-15-06, 05:39 AM
chandler's Avatar
Just to clarify my last post. The metal detector won't be magnetic, per se. It will be electronic, and will emit a tone and lights will illuminate when it detects metal. Invaluable tool when using older wood, or wood you may have taken apart to modify. Have a wonderful Easter yourself. Take care.
