casters for computer desk
Old 07-06-06, 07:29 AM
B
Unhappy casters for computer desk
I have an assemble-it-yourself computer desk that is very heavy, has vertical 5/8" dividers instead of legs and feet, and I would like to add casters or some method of moving it more easily to and from the wall behind it. I am pretty old and can't move it when it needs repairs, but would like to have it against the wall most of the time instead of always being a couple of feet away. It takes up too much space in my tiny apartment.
Apt is carpeted, which compounds my difficulty.
Thanx for any help.
Old 07-06-06, 07:45 AM
majakdragon's Avatar
bqmother, Welcome to the DIY Forums.
5/8" is not really thick enough to use the casters that go into a leg on most furniture. You may be able to use appliance rollers. I had them under a refrigerator so I could roll it out for cleaning. They are plastic and have a series of rollers. About 3" wide and 18" to 24" long. Moving would be restricted to straight forward or backwards. Carpet will make it more difficult but I think it would still work. Good luck.
Old 07-10-06, 09:09 PM
R
Re: Casters
They make all different types of casters. Your vertical divider legs sound too thin to effectively use plates. You should be able to find some bracket-type that will fit around them. They make L-shaped bracket styles that screw into the side of stock panels. They also have caster clips that wrap around stock panels so that you can secure a stem type caster. Rockler is a good place to start.
