Wood screws "stripping" when trying to use them??
Old 07-08-06, 03:34 PM
I am trying to do some home repairs and where I need to use wood screws to screw through a piece of 2x4 my screw heads keep stripping before fully screwed through (making them useless)
I am using a standard 2x4....and #10 x 2 1/2" -
Is this simply because my screws themselves are cheap?? - Or is my electric drill under-powered??
I am using Crown Bolt type screws (4 in a package for like $1.10) -
Thanks for any help advice -
Old 07-08-06, 04:11 PM
mango man's Avatar
drill a pilot hole
use some lube on the screw (soap works just fine)
use a quality screwdriver bit
drive at a slow speed
Old 07-08-06, 04:24 PM
Originally Posted by mango man
drill a pilot hole
Thanks -
I'll go buy a new screwdriver bit (that probably is it)...along with putting some lube/soap on the screws themselves -
Old 07-08-06, 04:46 PM
chandler's Avatar
Received 5 Votes on 5 Posts
Change drive mediums. Instead of phillips head, use something like deck screws with a #2 square drive or the ones that use a T25 torx bit. They will not strip out, and aren't brittle enough to break with the torque, as do the cheaper drywall type screws.
