Quick question on stair riser placement.
Old 07-10-06, 02:15 PM
Do the risers go on top or behind the tread? I want to be certain and not blindly follow what the existing stair has.
Old 07-12-06, 07:10 PM
chandler's Avatar
Received 5 Votes on 5 Posts
Behind the tread. That way the width of the tread will be the same, and if you are using standard bull nose treads and 1x risers on a 7:11 rise/run, the tread will stick out just a little (3/4") over the riser. Also, visually, the line between the tread and riser won't be seen when you ascend the steps.
