Lightly refinish solid Oak cabinets?
Old 07-11-06, 10:00 PM
W
I have a comndo that I am about to sell with solid oak cabinents in good shape. I have a few that have lost their sheen and a couple with some paint spots aoroubd edges.
Can I lighttly sand them with 200 grit sandpaper and then put on new clear coat? I mainly want them to shine ahgain and get the latex paint off of them too.
Will this work?
WarrenNVegas
Old 07-12-06, 05:11 AM
Received 291 Votes on 259 Posts
Welcome to the forums
That might work, alot depends on whether or not the varnish/poly is compatible with the existing finish.
Paint specs/smears seldom sand off without affecting the surrounding stain. You should first try a product like 'oops' or 'goof off' and see if it will remove the paint. Carefull scraping with a knife is often succesfull in removing paint spots.
Depending on what shape your finish is in, waxing may bring back the shine. WARNING - if you use wax and then decide you need to poly the wax must be removed first!!
