'sheet of quantity'!
Old 07-20-06, 11:21 AM
hi,
there is a vacancy in a woodwork factory for a draughtsman but the applicant should know how to make 'sheet of quantity'!
cab someone explain what exactly are 'sheet of quantity'?
thanks in advance
Old 07-20-06, 05:08 PM
chandler's Avatar
Received 5 Votes on 5 Posts
It is what we call a "cut sheet". BAsicially you lay out all your parts on either sheet goods (plywood) or on dimension lumber utilizing the maximum amount of wood and having little waste. In your instance, the draftsman would do it on paper, and the carpenter will follow the draft and make his cuts.
