10" table saw--using 7 1/4" blade
can anyone tell me if i should be doing this or not.
the 10" blade was a little dull so i replaced it with a 7 1/4" circular saw blade because at the time didn't have the 10" blade.
don't seem to want to cut good--want's to kinda stall at times.
thanks for your advice.
Even though the blades are travelling at the same RPM, the smaller blade has a smaller circumference, so with a smaller blade you have less blade slicing through the wood as compared to the larger blade that has a larger circumference (and maybe more teeth). It might get you by until you get the right sized blade on there.
I doubt the saw manufacturer would recommend using anything other than the correct sized blade.
True, you should use a 10" blade, but I had no problems using a sharp 7-1/4" blade on my old 9" Craftsman table saw. Did a lot of projects that way.
Sharp is the key...and some patience...until you get a 10" blade.
