Another handrail question.
Old 05-05-07, 07:35 AM
D
On my stairway going from my 1st to 2nd floor. Do I have to have a handrail on both sides of the stairway? One side has the post and handrail. The other side is just a plaster wall. Am I within code just using the handrail on the stairs?
Old 05-05-07, 08:04 AM
jatco's Avatar
Received 1 Vote on 1 Post
Not sure if there is a code issue here or not, for private residences, but fwiw, I only have a handrail on 1 side. Been like that since day 1 after the addition...20+ yrs ago.
Old 05-05-07, 10:27 AM
chandler's Avatar
Received 5 Votes on 5 Posts
Welcome to the forums! As far as code, it would be local, so check with them first. If you do have to add one, the only code item I can think of is you will have to return each end to the wall so you don't have a "pocket catcher" on the ends. After a trial fit, measure from the handrail to the wall and cut a 45 degree angle to where it will return to the wall. Swap the pieces (top to bottom) and you have the returns made. Glue and nail them in place.
Old 05-05-07, 01:29 PM
D
Thanks!
Thanks for the info so far. Hey Jatco, I own a Larrivee guitar that I bought two years ago. Those are made in Vancouver I think. Do you know of the place?
Old 05-06-07, 08:09 AM
jatco's Avatar
Dont know where his actual 'factory' is..but I know of a few of the dealers that distribute his guitars....
Looks like fine craftsmanship......... http://www.larrivee.com/
