Finishing Maple Cabinets
Old 07-19-07, 12:27 PM
Q
Question Finishing Maple Cabinets
I have 65 doors and 20 drawer fronts and also the cabinet shells and faces that are all Maple. They are about 5 years old and have no finish except thin sanding sealer which is very porous. I have read that sanding sealer is to be used with varnish or shellac only.
What is the process I need to follow to clean and finish (not stain) these cabinets? What is the speediest and best method to apply that process since there are so many?
Thanks!!!
Old 07-19-07, 04:08 PM
Not sure what condition 5 yr old sanding sealer might be in. But I would sand things smooth w/about #220, then apply a thinned coat or two of poly. Sand lightly after each coat. Then a couple of final coats. Oil based will be yellow or amber, which some like. Water based will be clear. I don't recommend shellac for anything in the kitchen, not a durable finish(only lasts a few hundred years on antiques, if no contact with water or alcohol), not even sure you can still buy varnish.
Old 07-19-07, 04:16 PM
Received 94 Votes on 83 Posts
Are you looking to change the color or just apply protective coatings?
Old 07-20-07, 04:31 AM
Q
Refinish Maple Cabinets
Hey Bill, what about the comment I read that says Poly doesn't work over sanding sealer? It is on this website under Furniture Finishing 9 - most common errors.
"Warning: Sanding sealer is not meant to be used below any polyurethane finish. Polyurethane finishes will not adhere to most sanding sealer and the polyurethane will peel off.
Tip: Do not use sanding sealer before using a polyurethane finish. The polyurethane will not adhere to the sealer and will peel off."
Minwax said I could use Polycrylic after sanding the sealer to rough it up. it is rather slick on the surface. Obviously, I don't know much about this product.
Mitch, I don't want to stain, just protect from further water damage.
I'm looking for a process of all the steps I need to use and also the fastest and easiest method, including tools, to apply those steps. I do have a large number to do amd I'm not a young chick.
Thanks for your help.
Old 07-20-07, 04:45 AM
George's Avatar
Benjamin Moore makes a sanding sealer specifically for use prior to applying their polyurethane.
The caution against standing sealer under poly used to be universal; with the advent of new techniques in the industry it varies from brand to brand.
Old 07-20-07, 10:46 AM
Q
Hi George
Sanding Sealer was applied by the manufacturer of the cabinets 5 years ago. I have no way of knowing what it really is.
Old 07-20-07, 11:10 AM
George's Avatar
The only admonition in surface preperation on the Ben Moore poly is adequate sanding - removing ALL the shine and scuffing the surface for proper adhesion of the new material.
No caveat as to sanding sealer, poly or lacquer as the previous finish - just proper sanding and cleaning before application of their product.
Dry time to recoat is about 2 hours. Assuming you have the space to work in, 2-3 days ought to do the trick.
Old 07-20-07, 01:47 PM
Q
Hi George
What product should I use to clean the cabinets that are close to the sink and stove before (or after?) sanding?
Is there a way to apply the poly(urethene?), beside brushing on, that would be faster, and better?
Should I do all this outside (except for the bases, of course)?
Thanks for the advice.
Old 07-21-07, 04:53 AM
George's Avatar
Sanding will go more easily with clean surfaces; I'd use something like Clorox cleanup.
Wipe down after sanding with a damp rag (paint thinner) to remove the sanding dust/debris.
Polyurethane can be applied with a roller. Several of my customers use a 3/16" nap roller when redoing floors. No reason why it shouldn't work on cabinets. As with a brush, the main thing is not to overwork it.
