Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Carpentry, Cabinetry and Interior Woodworking
Reload this Page >
Where could I find a round solid piece of red oak as a a table top?
Old 07-30-07, 07:50 PM
D
Received 1 Vote on 1 Post
Hi,
I was wondering if anyone knows a source for unfinished round read oak table tops?
I'm looking for ~30" diameter, ~1" thick piece.
Old 07-30-07, 08:24 PM
chandler's Avatar
Received 5 Votes on 5 Posts
30" solid red oak hasn't been around for much of this century. If you find it, the cost would approach the cost of gold. What you see nowadays is made-up table tops, which is the norm, and perfectly functional and sturdy. But good luck in your search.
Old 07-30-07, 08:25 PM
XSleeper's Avatar
Received 582 Votes on 535 Posts
vandykes has 30" round unfinished red oak tops for about $60 each. Solid oak, not veneer... but glued up from smaller boards, not one big one.
Old 07-31-07, 04:03 AM
A solid piece of any wood that size is not a good idea. It will warp and crack/split very easily if not dryed very carefully. Look at any antique that has large (wider than 8") single boards and most will be cracked.
Old 08-01-07, 06:35 PM
D
Glued from smaller boards, possibly even veneered would be fine. For my application it would be nice to find an entire top. I'm planning to use a a base with a small overlap with the top.
Old 08-01-07, 06:43 PM
chandler's Avatar
Don't veneer oak. Use individual 1x8 pieces of oak s4s, alternate the grains, join them with a biscuit joiner, then cut it round like you want it. You can make a pretty good cut with a band saw and circle jig. It will be more stable and can be finished with stain and poly.
Old 08-01-07, 07:06 PM
XSleeper's Avatar
in case you didn't catch it, Vandykes has these tops available to order. Due to forum rules, I hesitate to directly refer to a (for profit) website address that you could find if you Googled it yourself.
Old 08-14-07, 06:06 PM
D
Vandykes has some good choices. After cutting a 30" disc out of cardboard I would like to go slightly larger, maybe 32". Has anyone seen such a size?
Old 08-14-07, 06:22 PM
chandler's Avatar
No more than the 30" ones.
