How to ensure and square a frame
Old 08-15-07, 11:24 AM
I installed an attic door with ladder kit. AS per the instructions to ensure the frame is square i measured the frame diagonally. there is a 1/8" difference between the two measurements.
1/8" difference is suppose to be within the tolerable limits for squareness but the door is not closing completely flush; there is a slight gap at one corner which means my squareness is off too much.
how would i fix this? do i need to adjust the shims?
thanks in advance for any help
Old 08-15-07, 12:51 PM
jatco's Avatar
Received 1 Vote on 1 Post
Yes. That would be the best course of action, imo.
Old 08-15-07, 12:56 PM
Herm's Avatar
my same thought
Old 08-15-07, 01:55 PM
chandler's Avatar
Received 5 Votes on 5 Posts
It may not be the total squareness of the frame, but the unlevelness of the bottom of the unit. If one corner falls down or rises up slightly during installation, it will hold the door open in the opposite corner. Just a thought.
Old 08-15-07, 02:18 PM
jatco's Avatar
Chandler brought up a good point. You may also want to check all the bolts and connections at the pivot points etc for tightness. They may have become loose..or the wood has since 'dried' out more since originally made which would result in some loose connections/joints.
Old 08-16-07, 07:08 AM
i'll check the leveleness
and see if that works. thanks for the replies
