can't get full sheets of plywood upstairs
Old 02-07-08, 02:48 PM
rebeljeep's Avatar
I can't get full sheets of plywood upstairs. I have to cut them to 5 foot and barely able to get then upstairs. Just how do I put these 5 foot sheets down in a 10X8 room?
Old 02-07-08, 02:55 PM
HotxxxxxxxOKC's Avatar
I take it this is for a subfloor?
Could you add more joists to compensate?
Is there balcony of some sort that you can hoist these sheets up?
mango man's Avatar
cut them in half and work with 4'x4' sheets
Old 02-07-08, 04:15 PM
XSleeper's Avatar
Received 641 Votes on 593 Posts
Depending on what sort of construction is going on, if you are tearing out floors and ceilings, rip a hole in the floor and ceiling between 2 floor joists and make yourself an access hole to get the full sized sheets up.
Old 02-07-08, 04:50 PM
W
If your doing a floor dude, why not glue and nail a 2 by flush with the top of a joist the coincides with the biggest piece you can get up there? dont tare up that cieling your gonna hate yourself.. you now dont have that whimmpy 3/4" split and your cut man can be a hack ....think about it
dont forget the glue on the sheeting either mangos pr0bably right tho easy fix
Old 02-07-08, 05:43 PM
chandler's Avatar
Received 5 Votes on 5 Posts
Mainly because a 2x will not give the vertical support the joists are giving. There will always be a weak spot where the lumber is joined. Splitting the sheets in half and working with 4x4 sheets will meet properly on the joist heads and give proper support, dude.
Old 02-07-08, 06:17 PM
rebeljeep's Avatar
This is a subfloor and it's going over 7/8" planks. Do the edges have to be nailed or screwed to a joist? Do the sheets have to be staggered?
Old 02-08-08, 04:57 AM
Herm's Avatar
Red face
Most definitley nail or screw them to the joists ( I prefer screws), and stagger them.
I have the same problem doing a subfloor in my basement. I have 18 sheets of t&g osb I will need to cut in half to get down there.
Old 02-08-08, 07:36 AM
rebeljeep's Avatar
I remeasured and the floor is actually 9 X 101/2. If I use 4' sections should I use smaller pieces around the edges.
Old 02-08-08, 11:16 AM
badeyeben's Avatar
Use 2 pieces 5x4, 2 pieces 4x4 and 1 piece 5x2 1/2 and last piece 4x2 1/2. Use 2 inch decking screws (not drywall screws) everywhere except where you can hit joist, there I would use 3 inch screws. Some construction adhesive will help with the project. Be sure to leave 1/8 inch expansion space between all sheets and also along the walls.
Old 02-08-08, 11:19 AM
Ed Imeduc's Avatar
Wink
Put liquid nail down first for sure then the screws
Old 02-08-08, 11:31 AM
Herm's Avatar
Thanks guys, I forgot to mention the construction adhesive. Liquid nails or other. Even PL200 will work well. Really helps stiffen the floor, after the adhesive sets up.
Old 02-09-08, 08:14 AM
C
Received 89 Votes on 68 Posts
I had the same problem needing to get a dozen sheets of
3/4" plywood upstairs (plus I was working alone and too lazy to carry it). I had the yard deliver with a boom truck. I removed a window and they boomed them into the room. I think it cost $40 more than if i had picked it up myself at a big box.
When it came time for drywall I did the same thing.
Old 02-10-08, 07:48 AM
rebeljeep's Avatar
I'm using 1/2 in plywood. I figured it would be fine because the planks are a beefy 7/8" thick. I shopped for screws today and those 3" screws seemed awfully long! Even the 2" screws seemed long to me. I want to make sure I'm doing this right ,so what size screw should I use? Is my 1/2 plywood good enough? I'm going to finish off this floor with linolium.
