Counterweight Questions (Catapult)
Old 04-28-08, 06:31 PM
Angry Counterweight Questions (Catapult)
Hey, I realize this might not be a completely appropriate place for a catapult questions, but please bear with me.
I have built a catapult built like this:
Someone I know is saying that this is a counterweight:
I don't completely agree, because what this person says is that anything that "the hurling arm of the catapult must be attached at its base to the catapult's base, because if it is attached at any point other than the base, i.e above the base, it then has a counterweight and is no longer a catapult"
I'm pretty sure that since the bungee cord is part of the hurling arm that it is still attached at the base, and is not a counterweight.
Do you agree with me: Person A, or Person B (who thinks it is a counterweight)
-Thanks,
SmityPanda
EDIT: I just wanted to remind you that you pull down on the catapult's arm on the side that has the cup in order to fire it.
Old 04-28-08, 07:17 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
your friend is correct
I do not know the proper technical terms for the parts of the machine so bare with me on that.
what you have is not a catapult. It is a trebuchet, although a poorly designed one as the throwing arm and the pulling lever (the part you are asking about) are reversed in size from what they should be.
a catapult does not have this pulling lever but merely pivots at the base of the throwing arm.
a trebuchet generally uses a rope on the end of the hurling arm to increase length of the hurling arm and therefore providing a greater throwing distance.
Speedwrench's Avatar
some medival catpults had counterweights.woops I had forgotton about them I am wrong
Old 04-29-08, 01:21 PM
What I'm really wondering is if the piece that I drew the red box around really is a counterweight. It doesn't matter if the catapult is a trebuchet or not, only if the piece is a counterweight.
Old 04-29-08, 01:27 PM
nap's Avatar
nap
nap is offline
New Member
I guess this school question is just to tough for me. Sorry.
