Changing Circular Saw Blade - Not!
I've used my circular saw for some time and have never changed the blade. Now that I'm finally trying to do it, I can't - for the life of me - get the blade off. I follow the instructions to immobilize the blade - but the bolt just won't come loose!!!
Does anyone have a tip for me?
Blade
Different saws have different ways to hold the blade while you loosen the nut. Porter Cable has a push-in locking pin which locks the motor. In the past I have used a screw driver wedged into the teeth of the blade. I have also used pliers to hold the blade. If you try the last two, wear gloves!
What brand is your saw? Does it have a locking pin?
Make sure you are trying to turn the bolt the right way. Is it a left hand thread? If the blade is locked with the blade lock or by putting the screwdriver or allen thru the hole, it should come loose.
Skil classic? The gold housing? With the thumb operated blade guard? Man I love that saw! why don't more have the thumb operated guard?
Well, just checked mine, so its a RH thread. Jeez, don't know what else to suggest. Using the supplied wrench mine came right off. Just tried it to be sure.
Musta been way over tightened when they sent it out.
All I can suggest is put a screwdriver or allen so it traps the blade from moving and use a 6 point socket on the bolt.
Clamp a vice grip on the blade very tightly, or place the blade in a sturdy vice and use it as a fulcrum. Use a 6 pointed socket on the bolt, that is if you haven't already boogered it up too much.
You replaced the saw because of a seized bolt? I think I would have drilled it out first. OTOH probably as good an excuse as any to buy a new tool.
I've never seen a blade bolt that couldn't be loosened. Did you try a little mechanical advantage like a wrench extension?
msk...hope you come back to the thread. Don't throw it away!! I don't think they even have some parts for it anymore. I'd take it off yer hands if you'd ship it.
