Cutting strait lines
Old 06-12-08, 05:25 PM
P
I will be cutting mostly 2x4's with a circular saw. What do you folks use to cut with precision?
Old 06-12-08, 06:04 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Get a good aluminum "speed square", clamp it with your fingers and use it as a straight edge guide.
One is shown here....
http://www.homedepot.com/catalog/pro...ef11cd_300.jpg
Old 06-13-08, 04:37 AM
chandler's Avatar
Received 6 Votes on 6 Posts
To keep the speed square from slipping, always have the lip on the back side, so it hooks as you put pressure on with the saw.
Old 06-13-08, 04:38 AM
W
Received 19 Votes on 18 Posts
Cutting
Gunguy's suggestion is the way to go. You may need to reduce the cutting depth of you circular saw so the motor will clear the flange on the speed square. Good luck with your project.
Old 06-13-08, 04:47 AM
mango man's Avatar
heres what I use , my table saw is gathering dust since I got it
http://www.eurekazone.com/products/detail/sgs.html
Old 06-14-08, 09:46 AM
chandler's Avatar
Mango, you know you're not a very nice person, right??! Now I've got to check these out for panel cutting.
Old 06-14-08, 09:51 AM
mango man's Avatar
and here I thought you would thank me for showing you a tool you don't have
forum here has more info on the tools and applications
http://www.sawmillcreek.org/forumdisplay.php?f=26
Old 06-14-08, 04:07 PM
chandler's Avatar
I have to take the new tool, scratch it up, dip it in dirt and burn the box and wrapping. Otherwise I'll get grilled...."when did you get that tool? Don't you have enough...." Good site. I'll look after she goes to work.
