How to cut masonite paneling?
Old 06-16-08, 01:13 PM
P
Trying to cut masonite paneling in 2x2 squares. Do not have a table saw and afraid masonite will rip or chip. Any suggestions on how to do this?
Old 06-16-08, 02:59 PM
W
Received 17 Votes on 16 Posts
Masonite
Use a circular saw with a fine-toothed blade. You will need a dust mask.
Old 06-16-08, 03:01 PM
mango man's Avatar
buy 2'x2' "handy panels " or have the lumberyard cut it for you
Old 07-16-08, 01:23 PM
mikeTN's Avatar
Smile
Fine toothed blade; cut from back side; use a clamped straight edge;set saw only slightly deeper than cut to be made.
Old 07-19-08, 03:15 PM
G
You could also finish the edge with a router for a smooth finish.
Old 07-28-08, 11:05 AM
P
cutting masonite panels
use a very fine blade in a jig saw. set up some sort of straight edge that is clamped to the masonite and use it as a fence to guide the jig saw. Putting some masking tape on both sides of where you want to cut may minimize tear out... as will using a utility knife to score the cut lines.
