what should i use to stick glass marbles to wood?
Old 07-27-08, 09:27 PM
im redoing a coffee table.. the table has a raised edge so i decided to put marbles in the center. once there set a peice of glass on will go on top.
the problem is how do i get the marbles to stick to the wood and stay. the substance needs to be clear and stick to wood and glass.
i was thinking polyurathane or hot glue.
ive never really worked with polyurathane and i have a feeling hot glue may not be strong enough.
any suggestions would be helpful
Old 07-28-08, 02:40 AM
C
If the marbles will be under the glass and not supporting the glass, and will be glued to wood not paint, either hot glue or a clear epoxy might be the way to go. If the marbles will support the glass, a pourable clear epoxy such as is used for bar tops might be appropriate.
