New glued floor pops
Old 12-14-08, 04:22 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
A few weeks ago I put down a glued (to concrete) wood floor. We have 1 board that pops when you walk on it. Must no have enough glue under it. How do I fix? Pretty sure I have to cut board out and install new one. Hope to have a better way to fix.
Old 12-14-08, 04:54 AM
Drill a small hole(s), inject glue thru the hole, cover the spot with something heavy, fill the hole(s) with color matched putty. I assume you checked for hydrostatic water pressure before doing the floor???
Old 12-15-08, 03:38 AM
pugsl's Avatar
Had no water problem. Just 1 board that pop. Naturally it is in the most traveled part of floor. Will try your idea soon. Tks
