Mounting Router on Table Top
Old 12-16-08, 11:13 PM
kolias's Avatar
Received 3 Votes on 3 Posts
I have a HaussMann plunge router with and shank and variable speed and I want to install it on a table top. I have used this router occasionally in the last two years and although it is a very inexpensive router, it works just fine.
Due to space restrictions, I would rather install the router into my table saw top. The table saw top is 27x 44 and it is custom made by myself with two MDF sheets glued together. I have this saw for about 5 years and it works nicely. Another advantage of doing so is that I would be able to use the same fence / mitre as for my saw plus I will have easy access to the router for changing the bids, high adjustment etc.
Looking on the Web for ideas, I noticed that some routers are mounted directly under a table top and some are mounted with a table insert.
I would like to know the pros / cons for each alternative.
Thank you
Old 12-17-08, 03:46 AM
R
Received 1 Vote on 1 Post
mounting router
I would go with the drop in version. That way when you were using the saw you could remove the router and drop in a filler block. It would also make changing bits a lot easier. It would also let you remove the router and use it by hand easier. Just my 2 cents. RW
Old 12-18-08, 10:20 AM
Herm's Avatar
I have to agree with that. I have the same setup in my TS top and use the drop in insert. It makes it a heck of a lot more convenient to change bits. At least with my PC router.
It's really nice to use the same fence. I also put a T track in for a featherboard, and a hole for a removable guide pin for freehand routing.
Old 12-18-08, 10:29 AM
the_tow_guy's Avatar
Received 55 Votes on 45 Posts
Another vote for the drop in. Rockler, among others, has some good inserts:
Rockler Router Table Plates - New Larger Size - Rockler Woodworking Tools
Old 12-18-08, 04:13 PM
XSleeper's Avatar
Received 667 Votes on 617 Posts
I've got the Veritas base plate/table insert. You tip the router and insert it from underneath, then straighten it and drop it down into the hole.
Image credit: LeeValley
Old 12-18-08, 04:47 PM
mikeTN's Avatar
Talking drop in router
I have used routers and table saws for years. Had a router table but sold it. Call me slow, but I never thought about cutting a hole and using the table saw top as a router table. THANKS GUYS!! Who says 'OLD DAWGS' can't learn a new trick?????
Old 12-19-08, 02:05 PM
R
I also use the drop in method.
Robert Robillard.
