Did I just destroy my door frame?
Old 12-17-08, 06:03 AM
Unhappy Did I just destroy my door frame?
My house is about 100 yrs old, with a lovely, tall, arched doorway. There's a wood frame and glass transom in the arch. It appears that the frame is original and has only two coats of paint.
I sanded the door as best I could, in many places down to the wood (not sure what kind of wood it is). I primed the entire frame with Terminator 2 (duron) primer, as i had an extra gallon and stupidly didn't take the time to research wood primers.
Before priming, i noticed a bit of dry-rot along the bottom of the transom, so i brushed on what i thought was a wood hardener, but turns out was a weatherproofer/sealer (thin, muddy tan in color, not sure of the brand). Upon learning of my mistake, I let the weatherprooofer/sealer dry and applied several coats of Minwax wood hardener. I then primed over that as well with the Term 2.
So, I have essentially two coats of Term 2 on the whole thing and that one area with the primer over the wood hardener, which was applied over the weatherproofer/sealer.
Is this ok, or is there some other prep i should do before i put on the paint?
Thanks!
--Matt
Old 12-17-08, 03:09 PM
The wood hardener should go on bare wood. If everything dried(not sticky/tacky), and the primer is not falling off, paint away.
Old 12-17-08, 03:42 PM
thanks, Bill. the only problem now is that i need two consecutive days above 35 deg with no rain.
