level wall
Old 12-31-08, 04:35 PM
R
level wall
I bought a new property and removed the paneling above the fireplace. The wall is uneven with the face of the brick fireplace. What matteral should I use to level the wall?
Rick in socal
Old 01-01-09, 04:47 AM
Walls are plumb, floors are level, but I am nitpicking.
It depends on what you need. If the studs are not in a line and you only have 1/2(drywall) of space, run a string across the wall at 1' increments and shim as needed to fill in voids with cedar shims. Nail the shims in place. If you have a lot of space, install furring strips shimmed the same way.
Old 01-01-09, 06:05 AM
chandler's Avatar
Received 6 Votes on 6 Posts
And a pix or two of the problem may help us see what your problem is. You can post them on a site such as photobucket.com and copy/paste the IMG code to your reply.
