Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Carpentry, Cabinetry and Interior Woodworking
Reload this Page >
Which is a better way to repair a stripped screw hole that is too large?
Old 01-03-09, 01:06 PM
R
Which is a better way to repair a stripped screw hole that is too large? To insert broken tooth picks with glue into the screw hole or to inject epoxy into the screw hole.
Old 01-03-09, 02:31 PM
T
It depends on the screw hole. Sometimes a bigger and longer screw will resolve the problem. Match sticks, tooth picks, and wood dowels are options. Problem with epoxy is that it gets hard. Wood expands and contracts and the epoxy plug can pop or be pulled out. Too, if screw is installed before epoxy is completely dry, you will not be able to get the screw out again.
Old 01-03-09, 02:35 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Kabob sticks coated with glue work great.
Old 01-03-09, 03:41 PM
chandler's Avatar
Received 6 Votes on 6 Posts
A golf tee is already shaped like a #10 screw, and if you glue it in and cut it off flush, you almost have new wood to deal with.
Old 01-03-09, 04:13 PM
Gunguy45's Avatar
Super Moderator
Hey Chandler I agree, but not everyone plays golf, and some of the tees have so much paint or laquer on them the glue doesn't penetrate to the wood grain.
They fit perfect, but it all depends on the tee and the person.
Old 01-03-09, 07:17 PM
chandler's Avatar
I agree, I have to steal them from my BIL.
Old 01-08-09, 07:29 PM
mikeTN's Avatar
Talking
WHAt????? Not EVERYONE plays golf?? You have shattered my world!!!! How on earth do they survive???
Old 01-08-09, 08:13 PM
try dipping the sharpend end if a pencile in some glue, tap it into the hole and trim it flush give it about an hour and put the screw back in. as the screw goes in the graphite will flake out
just another great trick a very old craftsman tought me
Old 01-14-09, 03:09 PM
D
which is better
It depends to a large extent on how large the hole is. Depending on the situation, it may be possible to simply use a larger screw. I have applied glue to toothpicks and wood slivers and tapped them into the hole with success. On large holes I have done the same thing with dowels.
