Hanging Mini-Baseball Bats
I am trying to hang two 18 inch Mini Baseball bats. THey are going to be at about a 45 degree angle pointing to each other on a vertical wall. Does anyone have any suggestions as to how i can do this and what material i would need to complete this project? Thanks.
- one more thing i would not like to damage the bats in any way
do you want the hangers visable or invisable?
if invisable drill a couple of small holes on each bat then use finishing nails in the wall extending out about 3/8 in to support each bat. if you drill at a slight angle they should not fall off. you could also glue the nails into the bats and gently press them into the wall where needed.
if we're not supposed to eat animals why are they made out of meat?
If they will be hung on drywall, just drive the finish nails into the bats, clip off the heads and push them in as suggested prior.
