Half wall cap
Old 02-15-09, 11:39 AM
R
Question Half wall cap
I am finishing my basement and thought I would put wall caps(shelf boards) on top of the knee walls I have. Two of the walls are approx. 20' long and the aspen wood I am using only goes up to 12' length max. What would be the best way to join the pieces together?
Old 02-15-09, 12:03 PM
Received 319 Votes on 283 Posts
A miter joint and some sanding should give decent results.
Do you plan to paint or stain?
Old 02-15-09, 12:15 PM
R
I plan on painting the caps white. Maybe I phrased it wrong, but I need a way to connect pieces together to go the full length. I was thinking of using a biscuit joiner. Would this work?
Old 02-15-09, 04:07 PM
XSleeper's Avatar
Received 675 Votes on 624 Posts
When Marksr mentioned the miter joint, I'm pretty sure he was thinking of a "scarf joint" which is just 2 pieces cut at opposing 45 degree bevels, which overlap each other vertically, one on top of the other. These joints just need to be glued and pin nailed together to prevent movement. Even if the joint isn't perfect, a little filler and sanding makes the joint disappear completely before painting.
A scarf joint is always better than a butt joint, even if you use a biscuit. The 45 degree bevel gives you a greater surface area to glue and allows you to nail through both pieces at the same time. Butt joints have a greater tendency to expand and contract, breaking open the joint between them.
Old 02-16-09, 03:48 AM
Ya, I meant a scarf joint. As a painter I don't always know the correct terminology for carpentry work
I've painted behind carpenters that have used both methods and the scarf joint always looks better than a butt joint
Old 02-16-09, 03:53 AM
chandler's Avatar
Received 6 Votes on 6 Posts
I love going back to a job I have trimmed after the painters leave. They make us look sooooooo good! Tip of the hat, Marksr.
