Looking for thin backing for a CD storage unit
Old 03-15-09, 11:48 AM
K
I've built wooden CD storage unit (on coasters), and I'd like to add a panel on the back - the kind that usually comes with purchased DIY furniture kits: usually a lightweight cardboard material that you nail on with finishing nails. I don't need to paint it, and it doesn't need to hold the CD unit square (it's already square and secure).
Where can I find something like this? What words should I search for? The closest thing at Lowes or HD is a very thin plywood, which is much heavier than necessary for my project.
Thanks for any suggestions.
Old 03-15-09, 12:31 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Check to see if they sell "door skins" at your local stores/lumber yard. Thats about the thinnest thing you will find, unless you really do go to cardboard or some sort of synthetic material like FRP or counter laminate.
A door skin is very thin plywood..maybe 3/32-1/8". Can be just nailed on with brads.
Old 03-15-09, 12:50 PM
XSleeper's Avatar
Received 676 Votes on 625 Posts
You should be able to purchase sheets of 1/8" tempered hardboard. You'll probably want to predrill holes for the little brad nails you'll use to attach it.
Old 03-15-09, 02:15 PM
the_tow_guy's Avatar
Received 55 Votes on 45 Posts
I would opt for the tempered hardboard as well; I've used it for backing on several projects.
Old 03-15-09, 06:08 PM
willywhy's Avatar
Masonite? See if there is a small scrape piece at a near by cabinet builder.
