Need an experienced eye..
Old 03-29-09, 10:19 PM
Hello,
I know this is a DYI forum but need some knowledgable opinions on some work that I hired someone to do. I don't know the term to describe it, but basically hang some cedar 2'x6' boards from one end of the porch to the other (10 feet). (Please see pics)
When I saw his work I was a bit surprised he didn't use some sort of bracket to support the boards against the roof frame. I don't know much about carpentry but in 100 degree weather with 80% humidity, are those nails going to hold for long?! Should I go out and get some mounting brackets? Also, should I seal the cedar with something? I fear those things will come crashing down on someone.
I am considering building a gazebo and would like to know if this guy did a fair job because frankly he works cheap lol.
Thanks~
http://www.sleepydream.com/DSC00083.JPG
http://www.sleepydream.com/DSC00084.JPG
http://www.sleepydream.com/DSC00085.JPG
http://www.sleepydream.com/DSC00086.JPG
Old 03-30-09, 03:39 AM
chandler's Avatar
Received 6 Votes on 6 Posts
You've shown us macro pix of what we could see from a normal pix shot. He used non hot dipped galvanized nails or stainless, which should have been used. If this was to be in an area where it will be exposed, I would have used deck grade, torx head screws and would have countersunk them. You will have rust marks forever when those nails begin deteriorating.
Post a couple of pix of this installation from standing back a little so we can see the purpose of the wood. It may help us give better advice.
Old 03-30-09, 12:19 PM
G
Chandler is correct. This guy does NOT know how to do what he should be doing.
Wrong nails, toe-nailed (side) through the pickets, naied above the board- instead of below (out of sight), over-cut his notches on the wrong side of board, over-sized notches, open knot-hole showing, bad joint angle, and possibly used the wrong type board for the application, but .............."he works cheap lol" I'm sorry that you got less than you paid for ------maybe you didn't ? Be safe, GBR
Old 03-31-09, 03:36 PM
E
Is this really the suppost for a porch coming off the roof? Or is it rather a purgola over a porch?
I think anyone knows that this will not support a herd of elephants or anything.
You ended your post with an "LOL". You must have already known your answer -LOL.
Old 03-31-09, 05:30 PM
P
He looks like a professional hacker to me. Not bad for a cabin in the woods that you would expect to use for a few years. He does show consistency and good nail spacing LOL! Personally I would not accept anything but some kind of simpson strap/bracket with galv nails or deck screws. But depends where you are.
Old 03-31-09, 06:52 PM
B
Even adding brackets will not do much good as the boards are nailed to a piece of 1x that is the facia on the end of the rafters/ceiling joist (it's hard to tell what it is exactly). The 1x is only attached with 2-3 nails in each rafter. The facia should have been removed and the pergola framing, (for lack of a better term), run back along side of the rafter/ceiling joist, resting on the top plate if possible and nailed properly. Next time pay the $$$ for a qualified contractor to do work on your home. I have seen time and time again how the "cheap" contractor wound up costing homeowners way more than they saved on the original job.
Bill
Old 04-01-09, 07:35 AM
E
Originally Posted by Bill62 View Post
The facia should have been removed and .......
I think he is right -especially if we are talking any serious weight to be applied from above. That of which none of us knows for sure.
Old 04-10-09, 06:29 PM
mikeTN's Avatar
Unhappy
Bill
DITTO FOR ME!!! You get what you pay for!
