Repair Wooden Footboard
Old 05-02-09, 09:44 AM
W
Hello All,
I have a wooden footboard that has recently been damaged.
I have no idea what to do to fix this. I am fine building things from scratch, but fixing something like this is a bit different.
Here are some pictures:
Any suggestions or help would be much appreciated!
Thanks,
Craig
Old 05-02-09, 01:54 PM
Received 321 Votes on 285 Posts
Welcome to the forums Craig!
About the only way I'd know to touch that up would be to use an artist brush and a paint mixture to apply to the knicks. IMO it would be easier to sand/strip that section down and then restain/finish.
Old 05-04-09, 09:34 AM
R
Craig,
I agree with marksr. This may require the sand/strip and restain/finish treatment. However, before you do that, you may want to try this: Minwax® Blend-Fil® Pencil - Wood Maintenance & Repair - Minwax.com
In SOME cases, I've had these things perform miracles...but not always. If you've gotten to point of giving up and are ready for the sand/refinish, this may be worth a try first.
Good luck,
Old 05-05-09, 09:00 AM
George's Avatar
The blend-fil pencils by Minwax (and others) would be the easiest answer.
I normally use artist oil colors blended to color to repair this kind of damage - but I've been at it about 35 years.
Be aware that you can melt and blend the pencil "leads" to achieve a varity of colors.
