Finding studs in a plaster wall
Hey guys I'm trying to hang a 40' flatscreen on a wall in my living room. i have a cheap stud finder that is pretty much useless on my thick walls. Is there a low cost stud finder good enough to penetrate plaster and lath to find my studs? Any suggestions or advice would be appreciated..
I have the same problem. Look for an electrical outlet - sometimes you can see which side the stud is on. If not drill very fine pilot holes. (Not too deep)
The rest of the studs will be/should be on 16 inch centers. Patch the holes.
Since there are a million little nails in the lathe that hold it to the studs, an ordinary magnet works well to locate the nails. Wherever the lathe is nailed you have a stud.
