MDF Veneer Sheets
Old 07-06-09, 09:03 AM
MDF Veneer Sheets
Hi all,
I am wondering if mdf can be taken off existing particleboard easily (if yes, how so?). Also - if not, can another sheet be ironed/glued on over top of an existing piece? I am trying to cover an existing piece of furniture, but do not want to paint.
Thanks!
Jeff Beer 4U2
Old 07-06-09, 03:17 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Jeff, welcome to the forums! MDF is medium density fiberboard, and removing it from a glued or nailed surface will probably destroy it or what it is glued to. Can you post a couple of pictures on a site such as photobucket.com and copy/paste the HTML code to your reply post? That way we can see exactly what you have and may offer a better way to do it.
Larry
Old 07-12-09, 09:32 AM
T
mdf?
By "MDF" i think you mean the veneer that is on the core material - if that is the case then you would probably be better off to fillin any low areas and putting a new piece of veneer on it.
1- get the new veneer make sure it has a paper backer on it, this is the easiest one to use.
2-Cut the veneer to size
3-Apply contact cement to both the new venner and the piece of furniture
4- press in place - use a rolling pin from the kitchen
5- trim and finish
