A wooden panel with two colors of stain touching
Old 10-21-09, 08:59 AM
I recently saw a project (large wooden mirror frame) that Iíd like to emulate, but I don't know how it was done. It was one piece of plywood, with different colors of stain touching each other. Iím fairly certain that it was one piece, and I didnít see that a razor knife was used to separate the colors.
Any idea on how this was done without bleeding?
Old 10-21-09, 12:02 PM
Received 317 Votes on 281 Posts
Welcome to the forums!
While tape was probably used, care must still be taken to keep the stain off of the tape. The more you rely on tape, the more likely it is to fail The light color stain would be used first and probably sealed with poly/varnish before the 2nd color is applied.
Old 10-21-09, 12:27 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
And was it maybe some sort of paint as opposed to stain? I've seen some work with a graining tool that you would swear was stain.
Old 10-21-09, 01:34 PM
Thanks for the help (and greetings) guys.
I know it was stained, not painted.
I'll have to experiment on it.
Old 10-22-09, 03:38 AM
Another possibility is that the whole piece was stained the lighter color and a coat or two of poly was applied. Then a tinted poly [like minwax's polyshades] was used to "paint" the darker color.
Old 10-22-09, 04:29 AM
R
I think marksr's solution would work well.
You might also try a gel stain. It doesn't penetrate as much as regular stains and I would think it may be less likely to bleed into the adjacent area. In any case, a light touch and wipe on technique will probably work best.
