placing wood on floor
Old 11-23-09, 09:19 AM
Hello;
I am building, (for lack of a better term) ,a 'stage'in my basement, 8 feet by 8 feet and 1 foot high. I am using enginnerred TJI joists with 5/8 inch plywood ontop.
The joist will sit directly on the floor...now here is my question.
The basement is a cement floor covered with carpet, (no subfloor). I have been told that, If I put the wood directly on the carpet...the wood will 'wick' moisture from the cement floor (through the foam underlay and carpet fibers).
They are telling me I have to rip up the carpet and put a vapor barrier down..with some sort of underlay...to prevent this.
Is this true,or are they just trying to sell me roll of tyvek underlay??
Old 11-23-09, 09:52 AM
P
Temporarily Suspended
It's not a bad idea to remove the carpet under any circumstances, in that section. I would do it & maybe even use pressure treated wood for the joists.
Old 11-23-09, 03:59 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Mach7, is there a reason you are spending so much money on TJI when dimension lumber will suffice? You have no span requirements. Just curious. And I would go with T&G Advantech at 3/4" unless there is a reason for the 5/8". Advantech won't leave any voids at the joints.
Old 11-23-09, 04:00 PM
W
Will thestagfe e a permanent structure in the basement? If it is I would remove the carpet and isolate the I joists with plastic. If it won't be there long term, I would probably just build it on the carpet.
Old 11-23-09, 07:33 PM
Very good point. I actually was looking at 2 x 12's but found that the product that we get up here in Nova Scotia is very below average. I wanted something that was more 'accurate' with respect to being straight and true.
I am running 5 silent 8 foot long floor joists across with rim boards all around. Placing a sheet of plywood overtop.
FYI, the floor joist were less expensive than the 2 x 12's, not to mention lighter in weight.
Old 11-23-09, 07:36 PM
Hello wayne. The structure will be permanent, so i think I will take all of your advice and rip up the carpet and place the floor joists right on the concrete floor. Next question:
Can you give me some options on the type of underlay I should place between the wood and cement?
