Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Carpentry, Cabinetry and Interior Woodworking
Reload this Page >
Attaching a wood fireplace surround to a stone fireplace
Old 11-29-09, 06:21 AM
Hi, I have a cut stone fireplace which goes from floor to ceiling with an attached raised hearth(like a shelf with stone brachets about a foot from the floor. I want to attach a wood fireplace surround to the stone wall. It would sit on the raised hearth, but I don't want all the weight on the hearth. What would be the best way to attach it to the stone? What kind of drill and drill bits? Thank you. Joan
Old 11-29-09, 04:09 PM
There are rules about how close you can have wood to the firebox, check local code.
To answer your question, tapcons screws work well in stone or masonary. They require a very specific size hole(carbide masonary bit) for the size screw being used. Check home/hardware stores.
Old 12-03-09, 05:02 AM
If the stone is smooth then construction adhesive (Liquid nail) will work. Just be sure to brace it while the adhesive dries.
Old 12-03-09, 08:59 AM
W
Received 17 Votes on 16 Posts
Drilling
Drilling in the masonry joints requires a hammer drill and masonry bits.
