Filling holes in stud
Old 03-08-10, 09:22 AM
What is the best way to fill in several lag bolt holes in a stud in my bedroom? The holes are 7/32"x3" deep from an old wall mount bracket. I can reuse one of the holes for the new LCD TV I'm hanging. I was going to try and glue in some dowel pieces, spackle and sand is this the way to go and do they sell dowels around this size? Thanks
Old 03-08-10, 03:12 PM
Received 319 Votes on 283 Posts
Will the bolt be secure enough if you reuse that hole as is? If you aren't going to reuse the hole [or next to it] a couple of coats of joint compound is all that would be needed........ or am I misunderstanding the question??
Old 04-01-10, 01:16 PM
N
I too mounted my flat screen to the wall and I worry about removing it some day. Hum...May I should use 3/4 inch ply under the drywall on my basement that I am finishing.
Old 04-01-10, 02:34 PM
IMO it's always a good idea to install a 2x or whatever type wood is appropriate in the framing to accommodate heavy loads like a TV mount or cabinet.
Old 04-01-10, 02:44 PM
It sounds as if the walls are open and the studs are exposed? ???
If so, instead of trying to "fill" the hole, why not just add additional stud(s) wherever you want them. less than $3.00 per and a lot faster. Hope that helps
Old 04-01-10, 02:50 PM
Ya, a 2x is my preference although I'd probably go with a 2x6 [wider if needed] and install it flat- in between 2 studs at the needed height, that makes it easier to find some 'meat' to sink the screw into.
