Bubbles
Bubbles
I have a Broyhill dining room set and the top of the table there are some bubbles . what is causing that and is there anything I can do . thanks Roz
The bubbles would be a sign of water damage or moisture. Check your ceiling to see if you have any water leaking from somewhere. The other thing could be, you're not using coasters to put your drinks on, and the condensation from the glasses is taking it's toll.
To fix it, it would need to be refinished.
Its the veneer coming up. My table did the same thing. Probably from the wife wiping it down with a very wet rag. The veneer is cheap and the finish even cheaper. The only repair is to slice, lift and glue the loose veneer. It won't ever look perfect again. If your table is under warranty, take it back.
